John Altenburg
Where is the Power Factor Penalty! I found it!
The common residential rate will bill on KWH unless you see the letter "D" behind it. Then it will penalize you for going over a specific KW during peak demands.
This is were small companies start getting penalized for high energy consumption but not a low Power Factor. The Utility Co. figures an average power factor for residential and small businesses.
If they were to grow in size they should get on a new rate plan. This is when their PF really starts to matter. Simply said, these rate plans bill on the KVA rather than the KWH.
My clients bill shows clearly his KW is about 247 and his KVA at 321. That's a PF of .74!
I can get him billed on a rate plan that bills according to his KVA rather than the KWH. Average KVA cost is roughly $13 per. If I get the PF to 99% they will save $950 per month!
Wishful thinking??
Wishful thinking??
