Power line clearance
Fnewman
Dublin, GA
Sr. Electrical Engineering Manager at Larson Engineering
As a part of a current project, a new pre-fab metal building is to be constructed, the end of which will be near an existing pole line - no bare conductors, just 600v cables on messengers. We have been discussing what, if any, code required clearance would be required between these suspended cables and the building wall. TIA
I'm getting "not found" for those links.
P.S. - before anyone asks, the cables are not service conductors and are in an industrial environment.
To clarify, it is not a utility-owned line. Something like 3/c#2/0, 600v cable on a messenger.
The poster copied and pasted the abbreviated "display" string instead of the underlying URL.
Hopefully it will be corrected. You may also be able to find the links through a Google search.
Or a forum search with keyword "clearance" and user=cornbread.
