I have a 225 main distrubution panel located next to a PLC power monitor. The two panels are connected with 2 chase nipples. My delima is that the previous electricians routed the incoming power feed into the distrubution panel instead of the power monitor first. Can I route thru the distrubution panel to the power monitor and back to the DP main breaker since the cable is of the same incoming power feed? I cannot find anything in the NEC specifically pertaining to power monitoring panels and cables passing thru.
