toosmarttc
New member
- San Angelo, TX
We had intended to use a two tap transformer to drop 110VAC or 277VAC to 10VDC to operate a fire safety light. An alternate and lower cost design is to use a large resistor and a capacitor to drop the voltage. However, two separate circuits will be required rather than a single transformer. Overall, the capacitor circuit (even with two separate boards) will be less costly to produce and ship.
Are there any code issues on using a resistor and capacitor to generate a pulsating AC current that is rectified?
