I have to run some power and control wire and im confused as to what needs to be run in separate conduit. What is considered Control wiring? Where can I find a description in the NEC or the requirements?
One if the runs is from a control panel to a visual display unit. The unit is powered by 24VDC and has a control cable that connects it to the PLC in the control panel. Does the 24VDC and the control wire need to be run in separate conduit?
Any help is appreciated.
Thanks
Ron
Thanks
Ron
