Electromatic
- Virginia
- Master Electrician
I have a drive for a 140HP pump motor that stopped working this past weekend. The drive is within an AB factory-assembled cabinet. When you try to start it (for testing: via HAND on the selector switch), it immediately stops with an F2 AUXILIARY INPUT FAULT. Digital IN5 is setup up with the Aux Fault parameter. I DO have voltage on that input when trying to start.
Looking at AB wiring examples, that seems correct: I want a voltage/input/(1) on that channel for normal operation. I don't understand why it's registering as a fault.
On a side note: Can anyone confirm if it's usual for this input to be used as shown in the attached diagrams (basically running through a phase loss relay and a couple of thermostats)? I usually think of AUXILIARY as equipment outside of the drive/motor starter.
Thanks.
Thanks.
