PVfarmer
- Newport County, Rhode Island, USA
wow, these VBR batteries are pretty cool.
Howdy, check this out.
Lifeline AGM Batteries bring industry leading performance, and it's powered by the lowest Peukert Rating on the market. To our knowledge, no other AGM battery manufacturer can test their batteries to these rating, repeatedly.
Click here for a complete Lifeline AGM Battery life cycle discussion.
or here first:
http://www.lifelinebatteries.com/selfdischarge.php
BUT!!
For those of you new to the topic, flow batteries work by the interaction between two liquids flowing in parallel, typically separated by a membrane (some next-gen flow batteries ditch the membrane).
Compared to their lead-acid and lithium-ion cousins, flow batteries are relatively inexpensive to scale up because the basic infrastructure consists mainly of tanks and pumps.
Flow batteries also complement intermittent sources like wind and solar, because they can sit idle for long periods of time without losing their charge and kick into gear quickly when needed.
Both of those factors dovetail with the Obama Administration?s push to get more wind and solar power into the grid, so it?s little wonder that the Department of Energy is pursuing new vanadium flow battery technology on several fronts.
http://cleantechnica.com/2014/04/29/floodgates-open-vanadium-flow-batteries/
:?:blink:
hmy:
New York City?s Metropolitan Transit Authority is one of the largest single users of energy in the US, and today the agency is officially launching a next-generation energy storage system that is bound to turn heads. MTA has installed three CellCube vanadium flow batteries on the 25th floor setback of its lower Manhattan headquarters to demonstrate how small footprint, high volume on site energy storage systems can shave down peak electricity use and turn a ?smart? building into a brilliant one.
http://cleantechnica.com/2014/04/23/exceptional-step-forward-energy-storage-new-york-city/
(last April)
On Wednesday, New York City?s Metropolitan Transit Authority (MTA), which suffered its own Sandy-related shutdown, announced one of the city?s biggest energy storage projects to date: a 400 kilowatt-hour array of CellCube vanadium redox flow batteries at its new facility at 2 Broadway in downtown Manhattan.
The demonstration project features the first U.S. installation for the CellCube, built by Germany?s Gildemeister and brokered by Canadian partner American Vanadium. Partners including the New York State Research and Development Authority (NYSERDA) and utility Consolidated Edison are also involved, looking to test how multi-hour, modular storage systems like the CellCube can serve multiple tasks for the MTA and for the grid at large.
?The prime [question] is how these batteries can help customers make money by flattening their peak load curves,? Bill Radvak, CEO of American Vanadium, said in an interview this week. "Demand charge mitigation," the term used to describe this business case for building-side energy storage, is the rationale of energy storage companies like Stem, Green Charge Networks, Coda Energy and SolarCity in their commercial projects to date.
http://www.greentechmedia.com/artic...y-Brings-Energy-Storage-to-New-York-Citys-MTA
NOT EXPLODING = always a good thing!
As renewables become a larger share of the generation mix, the only solution going forward is cost effective energy storage. The global market demand for storage is estimated to be greater than $10B by 2020. However, the main challenge is that we still do not have a low-cost, safe, and highly durable means to store electricity that will enable ubiquitous storage.
WattJoule is addressing this huge market opportunity. We are developing a game-changing energy storage system that utilizes a liquid to store electrical energy ? a liquid that is over 60% water, inexpensive to manufacture in large quantities, and is highly durable. And, since it?s based on water, it can never catch fire or explode like other approaches.
http://www.wattjoule.com/
Impact Summary:
If successful, ITN's vanadium redox flow battery would provide storage capacity for residential and small-scale commercial applications at a cost approaching $1,000 per unit, compared to the $4,000+ price point of today's systems.
http://arpa-e.energy.gov/?q=slick-sheet-project/advanced-vanadium-redox-flow-battery
Yes, but understand that's your "nameplate" capacity. If you sucked every last erg out of the batteries on the first go, you'd destroy them. Effective capacity also depends on how fast you pull energy out. IIRC, in the end your 48kwh storage unit can probably deliver a total of 24kwh, and limited to about 500 watts. That's ball park, someone here may be a real battery guru and put some more solid numbers on it.
or here first:
BUT!!
:?:blink:
(last April)
Impact Summary:
