I had a Class 1 div. 1 area that I felt I could have wired different. I had two pumps in a pit that required seal offs. I thought instead of using a seal off; stub a sched80 PVC up from the metal plate covering the pit to protect the SJOW cords connected to the pumps and floats, and sealing the end of the PVC with duct seal to prevent any significant amount of gases through. This made sense to me b/c I do a lot of maintenance and I would rather pick out duct seal that Chink-o. I realise you can't use sched 80 in a class 1 div 1 per NEC but it seems that this would make sense since it would not rust. I didn't think any body would be smokin next to the pit to cause an explosion. Any thoughts or critiques?
