For a single motor to somehow become more effecient, maybe, but the OP is asking about two different motors, each of which would run at the designed speed.glene77is said:If efficiency improved by aprox. 10 percent, then the rpm would increase, and the FLA would drop.
LarryFine said:My guess is that the more efficient motor would use 8/9ths the current of the less efficient motor.
S'mise said:I would not even bother trying to do calculations on a multiple guess question like this. The efficiency improves by 10%... so wouldnt the current would drop by about 10%?
nakulak said:since power is a square of amperage, I would guess that amps woud be a factor of the squares of 8/9 ?
(or maybe the square roots ?)
Pi, on the other hand, R square.Mule said:Most of the roots Ive seen have been round not square !!
(For those playing along @ home)pfalcon said:...Aw = Amperage performing work = 1. ...
