mbrooke
Batteries Included
- United States
- Technician
Anyone have any clue regarding this combination? Or what year?
Did you forget a picture?
That is interesting. Did you take that pic or did someone send it to you? Reason I ask is the washer looks new. Did someone cut the ground blade off?
The picture is there just fine; not sure what iwire is talking about. Maybe his browser is not loading pics...
The plug is not inserted all the way. Look at the gap.
They are fairly common in my neck of the woods. I would guess circa 1950's.
Probably earlier. I have them in my house which was built in the 40's. They are called 'double T slot' receptacles and are no longer allowed by the NEC. They could be used for either 120 or 240 volt circuits, and accepted both 15 and 20 amp plugs.
How about the receptacle adapter that screwed into a porcelain lampholder?
Have you ever seen a made-for-US market appliance or lamp that used an ungrounded 15A 250V 2 prong plug? I've never even seen a 15A 250V 3 prong plug on an appliance, tho 20A plugs are quite common on hotel PTACs, and the last we put in at a residence was for a 4kw forced air space heater.
But they still make them![]()
But wait, that would mean such an outlet was indeed good for 250 volts, right?
Sure they were- they had the rating. Even some old light switches, light fixtures,even Hubbell t slot socket adapters had a similar dual rating. But don't bother asking why the ampacity limitation for gen/lighting ckt over 125v- I have no idea, and obviously the question would be where would such voltages be used/available over here for those ckt types. Many dwellings built in the early 1900s that had these devices installed only had 120v svcs.
The theory about 240v equipment being used in those recs makes sense except that there is a dearth of equipment from that era that could have used 240 and had a tandem blade plug that could fit the t slot rec and as mentioned above the other "parallel only" rec type and other devices had the same dual rating. Its also doubtful that, even then, such a device would be permitted in which an accident (120 equipment hit w/240) could so easily occur if the outlet's true voltage was unknown.
True, but in my eyes you would not list something as 250 volts unless it had the option of being used as such in the real world. For example, my understanding is that keyless sockets are listed as 250 volts because they can be applied to such a system when sold in countries that use 230 volts.
