mtfallsmikey
Saw them at Lowe's yesterday.
Like I said, in this case with the t slot it had to do w/ the NEC. I don't think the manufacturers of the old devices were trying make them compatible with other voltages used globally
Maybe not then, but why does a keyless socket have a 250 volt rating? Why not 120 or 277?
IIRC, there was an NEC 10 amp limit for lighting ckts originally- this was likely because of circumstances surrounding the lack of conveinence recs/modern branch ckts in dwellings at that time- think of an iron plugged into an adapter screwed into a lamp with is plugged into adapter screwed in ceiling socket and all of that small conductor (cords) carrying that load- a lot of fires then. Eventually it was raised to 15a in the 1920s (makes sense b/c of the growing use of wall recs in new installations deeming all those adapter doohickeys/cords draped everywhere increasingly unnecessary) , but the old rule was still in effect for lighting ckts over 125v and stayed that why until the '50s- no clue why as it made no sense. (sorry to sound repetitive)
Its ok, Im just as puzzled.![]()
Installed the receptacle or the adapter...maybe both? In most cases landing the ground lead to the plate screw was as effective as leaving it hanging, that screw was not bonded to any grounding source. I also have one of the screw shell adapters that I keep in the case with my circuit tracer.Sorry, but I had to laugh (geezer moment)... I installed many of these when I was a young lad. Ground lead from the adapter was supposed to land on the plate mounting screw, few ever made it. How about the receptacle adapter that screwed into a porcelain lampholder?
I have a couple, they are still being sold. They are great for using a plug in breaker tracer sending unit to locate a lighting circuit breaker.
They are also UL approved.
Don't know how readily available they are these days but we used to buy 230 volt lamps and put them in outdoor luminaires as security lights (operating at 120 volts noinal). Low light level but very long life compared to ~120 volt rated lamps. Photocells controlling them needed changed before lamps ever needed changed, in fact never ever recall changing such a lamp because it simply burned out.
... my understanding is that keyless sockets are listed as 250 volts because they can be applied to such a system when sold in countries that use 230 volts.
It's hard to imagine that the Tesla Westinghouse 1895 demonstration of useful horsepower (three phase AC motors) supplied from a generator eighty miles away (the Niagara Falls hydro electric plant) is only 120 years ago.
There were no "standards" to speak of, for AC power distribution at this proof-of-concept demonstration. . . all the AC standards followed.
The trap, in my opinion, is to try to understand the creation of materials standards through the lens of today's standards. Can't be done.
If you are talking about the 250v/660w rating on some lamps, I think that's just the Max rating of the socket.
:thumbsup:.
Why 250 when the light will only be applied on a 120 volts circuit?
Other countries that use 230-250V power? Overkill in case it's accidentally connected to 240V here?
because they make (made) 240V light bulbs. Often used in industrial locations.
For 240 volt ungrounded delta? Why not 277 volts when that was coming about?
I don't believe what is grounded or ungrounded has much to do with the rating. NEC does require the shell to be the grounded conductor if a grounded conductor is utilized.For 240 volt ungrounded delta? Why not 277 volts when that was coming about?
277 volts - I think you need to go to mogul base. Some medium base lamp holders are made with a pulse rating for starting of some HID lamps, but normal operating volts is still under 250 AFAIK.
My thinking, it could be connected to 240 volts in the real world. Which leads me to think this: those double T slot outlets could be used for either 120 or 240 applications.
They do make 277V 100W A19 medium base bulbs; I use them for load-testing various products at work. Loading down 20A of 277V with bulbs gets quite toasty...
We also use 3 120V bulbs in series for testing 347V
Tough to find as most are rated at 250V max due to 210.6. I used Leviton L9878 which is rated at 600V.What are the 277 volt lamp holder like?
Your future's so bright, you'll need to wear shades.They do make 277V 100W A19 medium base bulbs; I use them for load-testing various products at work. Loading down 20A of 277V with bulbs gets quite toasty.
I think I have run into those a time or two in the past.Your future's so bright, you'll need to wear shades.
I stumbled onto this curious item. I'm going to install it in a prominent place in my living room as an architectural/historical curiosity. (my house was built in 1927)
View attachment 15584 View attachment 15585
