Alwayslearningelec
- NJ
- Estimator
Simply splice together 2/0 THHN in a junction box what's your preferred splice material/method to use....barring any spec calling for particulars. Split bolt, Ilsco tap block etc.
Just a 150' horizontal run where we are transitioning from EMT/THHN to MC cable.Ilsco/polaris type splice. On something like a riser with multiple splices crimp connectors with cold shrinks.
For that I would use an Ilsco type. As Don mentioned crimp type are the best but require more advanced tools.Just a 150' horizontal run where we are transitioning from EMT/THHN to MC cable.
Crimp is same as butt and barrel splice?For that I would use an Ilsco type. As Don mentioned crimp type are the best but require more advanced tools.
Butt splices could use set screws vs a high pressure crimp.Crimp is same as butt and barrel splice?
Yes there are many names for the same thing with different variations depending on how the wire is connected. What I'm referring to is one of these which is compressed by a tool and insulated with a cold shrink.Crimp is same as barrel splice?
Same here as far as the connection device, by my preference is for heavy wall, glue filled, heat shrink....unless I am outside in cold temperatures, then I use cold shrink.Yes there are many names for the same thing with different variations depending on how the wire is connected. What I'm referring to is one of these which is compressed by a tool and insulated with a cold shrink.
crimp usually much less expensive, if you already have the crimping tool. And likely better overall connection than a mechanically reversible connection.For that I would use an Ilsco type. As Don mentioned crimp type are the best but require more advanced tools.
I've seen that done and always wondered if the terminals are listed to be used that way. Seem somewhat prevalent in motor connections.Or use a crimp on 1 hole lug on each conductor, with SS nut and bolt, 3m tape sticky side out, a bit of insulation pully and then 3 over it all.
Do they specify anywhere in listing what you must bolt it to? It just has a hole in it to secure it to whatever you are going to attach it to and a crimp barrel to land the conductor in.I've seen that done and always wondered if the terminals are listed to be used that way. Seem somewhat prevalent in motor connections.
The only way I have ever done motor connections, except on the larger ones I would use Raychem GelCaps in place of 130C and 33+ tape.I've seen that done and always wondered if the terminals are listed to be used that way. Seem somewhat prevalent in motor connections.
What do you call a large motor? that can vary quite a bit from one person to another.The only way I have ever done motor connections, except on the larger ones I would use Raychem GelCaps in place of 130C and 33+ tape.
