Is it possible to test a breaker somehow under various conditions to check its operation?
I'm not talking about high amperage breakers in commercial applications, just your average everyday snap-in type breaker.
I have a trailer that is fed by a 100 amp breaker mounted on a pole outside that feeds into a panel that has a 100 amp main breaker.
They were losing power at various receptacles that weren't on the same circuit. I wasn't there when it happened (seems intermittent ). By the time I arrived it stopped happening. The only common thing I could see when checking everything out is that the ckts that lost power were on the same phase.
I asked about the 240v loads, range, dryer, etc. they hadn't checked those items.
Voltage throughout the panel checked out ok when I was there.
I'm kinda wondering about the main breakers, either outside on the pole, or inside in the panel.
Is there a way to test a breaker where you try to push a breaker to its limit, just to test it out (without damaging the breaker)?
Thanks!
Thanks!
