Price for jacuzzi
How much for material to wire a jacuzzi fifty feet away...
Probably somewhere between $10 and $10,000,000? Care to give any details of what one might encounter doing this job, what is there for a source, what the specifications of the jacuzzi are?
Is that fifty ft going through an unfinished basement to a panel? If so you are in luck. If it's fifty ft from a house and you need to bore under a drive way it's not so easy.
As Kwired suggest, get more information. The best way is to actually go look at the job and figure out how you are going to wire it and then price the materials yourself.
I once did one in rigid conduit because I could only trench about 8" down and then it was solid rock.
It's fifty feet straight up from the master bedroom. The quote has to include the cost of installing a steel tower with elevator and an aircraft warning beacon.
