Pricing?
Re: Pricing?
A 100 amp service for $700 is a heck of a bargain in this area.
Hey I wonder why we have trouble raising our rates. :roll:
Re: Pricing?
Originally posted by briangordo:
thats with the custmer buying all the material.
NOT !
So who is responsible when the 0.38? Home Cheapot device fails/breaks...now is that callback a freebie?
Letting the customer buy the material is foolish.
For starters, how do THEY know what YOU need? Oh, yeah...you write them a shopping list. There's a freebie.
How about your expertise (aka, preferences) in selecting the material? Some guys use RX conns with screws, some use "black buttons"...whatever the material, YOU select it for a reason...cost, ease of installation, failure rate, etc. Another freebie.
How about the delays from the customer buying the wrong stuff? Another freebie as you explain a stove outlet and a dryer outlet ARE different.
This goes on and on until we arrive at the callback phase of the job....another freebie.
The point is: YOU leave a lot of money on the table when having "the custmer buying all the material".
Freebies aside..it's pretty dam unprofessional...unless you're a certified "trunk slammer" that also let's the HO pull the permit :roll:
Your "friend" is working harder than he needs to...and ultimately working for a lot less than he really could be making - unless, of course, he slams his trunk at 11:00PM and calls it a "day".
[ January 07, 2006, 05:44 PM: Message edited by: celtic ]
Re: Pricing?
sounds like its really bid like new construction if walls are open and there is no insulation.. otherwise you could consider charging time and material like I do if there is lots of snakeing involved and lots of variables you cant screw up with time and material :)
Re: Pricing?
Thanks to everyone,
I recaculated my bid at 6600.00. Thats $3 per sq/ft plus $1200 for the 200 amp service. We'll see if he goes for it. Since I do this on the side I am making pretty good money on the job. Hopefully nothing there that I did not forsee. Thanks again for all the help. I am picking up the National Electrical Estimating guide from Ed Tyler today.....maybe that will help me. I just want to make sure I spell everything out to the contractor as to what I am going to install per my proposal so we don't run into that "I thought you would do this or add that, the other guy I use does this and adds that for nothing" you know the type.
Well Thanks again
[ January 09, 2006, 10:11 AM: Message edited by: velocity ]
Re: Pricing?
Yes, definitely spell out every item as you plan to install it. When I bid a job like this you can look at everything in the house and find it in my proposal. Should be no surprises for either side. Good Luck.
Re: Pricing?
Originally posted by velocity:
Thanks to everyone,
It would be a good idea to keep close track of your time and costs on this job and compare it to what you estimated. That should give you a good idea if your bid was right. It can definitely be a hard lesson to learn, but I think anyone working as an EC learned plenty of lessons exactly the same way when they first started out. I know I sure did.
Yep. This comes up all the time. If you are doing a fixed bid, then you have to be very specific about the scope of the work. Fixed bid means fixed work. I just finished a kitchen remodel that would have been a nightmare if I gave them a fixed bid. Gotta love T&M! :D
Re: Pricing?
I don't even see how it would be possible to do a 100A upgrade that cheaply. I did a 150A upgrade a few months ago where the materials alone cost more than that. I did the job for $2000, and the homeowner was so happy that I did the work for such a "reasonable" price that she referred me to a lot of her friends and colleagues. No way would I upgrade a service for $700. I get more than that for a panel swap.
Re: Pricing?
you should figure out how time you will spend purcahsing materials and settting up the job such as unloading matrail form your truck also waht up clean up time
Actually, if you used labor units on all materials, these things are included in the unit.
Re: Pricing?
He hasn't called back so I guess I was to high. Oh well I couldn't see myself doing it any cheaper than $6600.00. It would of been an easy job but heck if you go to low he'll expect it everytime and I would never make any money.
Thanks to everyone that helped me out.
Re: Pricing?
Now you're on the right track. Don't sell yourself short.
