Hi-
On wiring a large private boathouse with an upstairs heated living room and fire place is it the general wiring articles in the NEC that are required? It seems strange that article 555 is not required because it is a private boathouse. The boathouse is located approximately 25? from the shoreline and will require a remote panel within. I know that it is preferred to wire in accordance with article 555 but have encountered some opposition. Are there any other codes or references to the wiring of private boathouses? FYI there is deck/docking on 3 sides of it. It appears that there will be about 160 outlets (seriously) throughout including luminaries directly over the boat slips, on the outside of the structure, low level dock and deck/dock lighting. Thank you for you comments.
