brantmacga
Señor Member
- Georgia
- Former Child
electricmanscott said:You still need to comply with the 25 ohm rule.
where does it say that?
brantmacga said:where does it say that?
Yes but you no longer have the water pipe as a ground right? Because the POCO made you disconnect it. So now you need 2 ground rods or something else along with your one ground rod.brantmacga said:it was my understanding that the water pipes are the grounding electrode and the ground rod is the supplementary electrode, thus meeting the <25 ohm requirement and negating the need for a second ground rod.
Don't have the book in front of me but you DO have to comply with the 25 ohm rule even if you have a metal wp as your electrode.brantmacga said:it was my understanding that the water pipes are the grounding electrode and the ground rod is the supplementary electrode, thus meeting the <25 ohm requirement and negating the need for a second ground rod.
steelersman said:Yes but you no longer have the water pipe as a ground right? Because the POCO made you disconnect it. So now you need 2 ground rods or something else along with your one ground rod.
