Gkarl
- Seattle area
After installing 4" PVC conduit in a fully concrete encased duct bank the 90's that turn upright to head to the next level ended up being waayyyy out of plumb once the next section of conduit was fitted to them. Basically we have about 3 inches of the 4" conduit sticking out of the concrete duct bank with a glue on threaded coupling for metal conduit to be run vertical next. Once these metal conduits were screwed on the inaccuracy of the plumb condition really showed. The contractor took a weed burner torch and slowly heated the 4" conduit just below the glue on coupling in order to bend the conduit enough to get it plumb. In the process, the 4" pvc pretty much stretched on one side but buldged quite a bit on the other side (where the compression was). It's one ugly piece of work BUT... will this method do any real harm... it will eventually become a vertical concrete duct bank completely buried. Can't seem to find any "best practice" information on means and methods for heat bending 4" pvc. Can anyone help with this issue or provide a best practice sort of "code"?
