- Wisconsin
- PE (Retired) - Power Systems
My reply was assuming he was using the correct selection table for the application (sounds like it was sent with the controller - so the chances of it being correct table are pretty high, but can still be factors that may dictate using a different table). Using the correct table for the application will result in compliance with NEC requirements
If using the correct table for the application and the current value needed is not in the table, you basically need a different controller with a different possible current range for the overload elements available to it.
There are many tables in the Digest, you need to look at selection information at the beginning of that section to determine what table you need to use for your application. Same overload element has different amp ratings depending on conditions at the point of use.
The OP is answering a homework problem.
This has little to do with an actual application.
