Joules Watts
New member
I am attempting to install a Satellite dish to the top of a 2 story home in Florida.
My plan is to mount the dish to the roof, run the RG6 video cable as well as a messenger ground wire from the dish, down the back of the house to a Dbs grounding block located near the bottom.
Then I want to connect the grounding block to a new 8 foot grounding rod with 10 AWG copper wire.
The cables & messenger wire will be exposed and be tacked to the house with coaxial staples.
My questions are: :-?
1. Is a messenger wire from the satellite dish to the ground block necessary?
2. Am I allowed to drive a new grounding rod into the earth or am I supposed to use the house ground?
3. Should the cables be encased by a protective shield?
4. Do I need take any other steps in order to comply with the NEC?s code requirements?
Thank You!
Thank You!
