proposals available for viewing
I see NEC-P01 which covers 100
I see NEC-P02 which does 110- 220 and then Annex D
I see NEC- P03 which starts at 300- thru the rest
215 and 225 I don't see-- what is going on or am I looking in the wrong place.
Article 225 is in CMP 4's bag of proposals. Close to the top of the list of downloads. ( NEC_P04 )
Don! Thanks for the link. Way cool. :thumbsup:
I think my dumb brain has finally figured this out. The proposals are listed based on CMP Numbers-- ie. cmp #18 is responsible for art. 406, 410, 411, 600 and 605. Boy I am thick-- Now I see my other proposals.
Well it looks like 17 of the 24 I submitted made it thru phase 1. I suspect 0 will make it to the end. :lol:
Dennis,
Nothing has made it through anything. This is just the actual proposals that the code making panels will look at in their January meetings. If you don't find a proposal that you submitted, it would be because it was lost somewhere between you sending it and the NFPA compiling them.
Dennis,
Well 7 got lost in the emails then. Dang.....
I hope they produce the ROP and ROC in this same format. The single column format they used here is much easier to read on a computer than is the two column that the NFPA normally uses for the ROPs and ROCs.
