I proposed the following 2008 changes:
1) 110.13 text addition- Equipment located outdoors shall be mounted not less than 24" above grade.
It is becoming practice of mounting equipment, mainly A/C disconnects, very low to the ground. This creates a problem during snow and rains, not to mention in some cases physical damage.
2) 210.8 text addition- GFCI devices shall be readily accessible.
This would eliminate GFCI devices from being located behind objects not easily moved such as refrigerators, freezers, under tubs etc. When these devices trip they are hard to find and sometimes impossible to reset.
3) 210.8(B) reorganization- Compile and incorporate ALL GFCI requirments for other than dwellings into 210.8(B) in order to avoid confusion and possible omission of a particular requirement. Now it would lead some to believe only those now listed are required. All articles requiring GFCI protection should be at least noted in 210.8(B)
