K8MHZ
- Electrician
Let's face it, if he had to add the forth conductor at that point he might as well do away with the old meter base.
He would kind of have to, wouldn't he? I don't see a way to legally leave it.
While perhaps not practical, could one just land the EGC in what is normally the neutral lug and run the neutral straight through the enclosure? Would the (now supplemental) analog meter still work correctly, or does it depend on having the neutral landed on those lugs?To add to above, how do you feed this with a separate neutral and ECG coming from an OCPD ahead of it, is basically my question.
Cheers, Wayne
I don't see that there is enough room for that. Certainly not for a splice, and pulling a neutral through the box (whilst the rest of the conductors are terminated there) would be no fun at all.
The meter would still work with the EGC only at the middle lug. The meter isn't connected to the neutral, just the hots.
I dunno about that.Plenty of room for a Polaris or similar connector for the neutral, only needs to have 2 ports.
How much room may depend on the type meter you have. Around here most all there is is OH/UG style that have wider cabinet, OH only cabinets I can understand will be more crowded.I dunno about that.
How about you do it the first time and I watch?
Now we have lead hazardsWouldn't it be easier to cover the outside sides and back of the meter enclosure with lead flashing?Then the only RF emitted would come from the front of the meter away from the house.
Since we are talking about RF and not particle radiation, aluminum or copper flashing or even galvanized steel would work just as well.Wouldn't it be easier to cover the outside sides and back of the meter enclosure with lead flashing?Then the only RF emitted would come from the front of the meter away from the house.
At same time the guy living in the house probably has WIFI, several wireless remotes for various items, wireless phone(s), etc. all giving him a higher dosage of RF then this power meter is:roll:
