One of the best things I did for a house I used to have was install a full-length ridge vent when the singles were replaced; made a huge difference.
yes thank you.
there was a ridge vent. I think it was installed about 10 years ago when it was re-roofed (two layers) it was on two sections a couple ridges. they weren't really long and there was a couple leaks that a roofer said their may be an issue with pitch not being enough so water may be getting in. He removed it and put in regular shingles. Was thinking about adding a ridge vent back again but not sure it's enough for the NFA thing (doubt it) and also when he pulled it up this past fall and it hadn't rained in a few days it was a bit moist underneath like it was wet from side driven rain.
Besides protecting the roof system the other reason it needs to be done is that a new air handler was installed in November. Pretty sure although they're made for attics that heat can't be good for it.
Thanks again
