150939-0814 EDT
petersonra:
You did not understand what I said. RTL and TTL are not specific to a particular voltage level, rather they are an output circuit concepts.
RTL has a pull-up resistor and a pull-down transistor. In the high state the output impedance is the value of the resistor, and in the low state it is the parallel combination of the pull-up resistor and the low impedance of the on state of the transistor.
A TTL output circuit has both a pull-down transistor and a pull-up transistor so the output impedance is low in both states. Usually not quite  as low in pull-up as pull-down.
Both types of circuitry were generally built as integrated circuits at the 5 V level. But the same concepts apply at 24 V or 120 V or whatever voltage level is practical to work at.
TTL does provide better noise immunity than RTL.
The difference between RTL and TTL is the difference between a SPST switch applying a voltage to a load (low impedance when the switch is closed, that of the voltage source, and high impedance of the open circuit, largely the wiring capacitance), and a SPDT switch that connects the load to the high end of a voltage source (low impedance) and the low end of the source (again a low impedance).
