Grouch
- New York, NY
The following link is an article on x/r ratios.
If you look at page 4, there is a graph at the top (Figure 4), and a table at the bottom (Table 1).
For Figure 4, which is a graph of the x/r ratios and (peak asym current / RMS sym current), does anyone have this in tabular form, that way you don't have to estimate the value on the curve, but can see actual numbers?
For Table 1, is there a more complete table with the test x/r ratios? For example, showing the test x/r ratios for other equipment (switchboards, distribution boards, transformers, etc.). ARE there even test x/r ratios for switchboards / panels? There is no information on Google. And I do not have SKM unfortunately.
