Grouch
- New York, NY
What do you mean by 'helically wound'?Because the MFG did not provide you with any literature to state you can use a CL fuse to raise your SCC rating in combination with the CL fuse you are Helically Wound.
Not following... so you're saying to calculate the MF adjustment at the unit. What text X/R ratio am I using at the unit?Assume your SCC at the unit is 4.7K and your calc yields an X/R of 2.
Local 10K rated OCPD.
Here I would say you now must use your MF adjustment to see if you fall below 5K...I leave the math to you.
The equation is MF = (I asym @ X/R calculated) / (I asym @ X/R tested).
I use the calculated 4.7k and x/r of 2 to calculate the numerator.
I use the tested 5k and x/r of what?? to calculated the denominator?
And then I run the same calculation at the OCPD serving the unit you're saying, further upstream from the unit?
