for those that install gas dispensers or anyone familiar with fuel dispensers . The dispenser has a ExProof factory J box with an intermal terminal block where you terminate the wiring needed for dispenser operation. I know you need a seal off before the EP factory J box. If I install a conduit from EP factory J box into the dispenser cabinet, basically the area where the card readers and electronics are stored, do I need to install a seal off leaving the EP factory J box and into the dispenser cabinet.? Or will that 1 seal off before the factory Jbox sufficient ?
