I tried this a long time ago for a similar issue with low voltage dimmers and it didn't work. There were multiple LV transformers working circuits of LV lights in a large kitchen on many different switches. The problem was that when any set of lights was switched on or off the other sets would blink. I assumed this was caused by the inrush/spike on the transformers so I added caps to each transformer circuit thinking the caps would hold up the voltage and absorb the spike during the time the other transformers had inrush. looking back, I think the problem was due to the LV dimmers not being able to handle the spike/dip when the other transformers energized. I think the best fix would have been in the dimmer design not necessarily trying to control the distortion at the source. With this said, it is certainly worth a try but ultimately I think the problem is with the LED drivers.Has anyone tried putting a run capacitor on a cord and plugging it into the the receptacle feeding the offending appliance?
any suggestion on a filter ??I suspect that the problem is with the LED drivers interpreting high frequency noise as a dimming signal and adjusting their output.
Different LEDs might solve the problem, or a good noise filter (on the LEDs or on the offending appliance) might help.
Drivers are often some combination of constant current, or constant current for max output combined with PWM for dimming.
Jon
You might try a ferrite choke on the washer cord. They don't cost much and are easy to install. Might be worth a try.any suggestion on a filter ??
Wouldn't the capacitor just become a load when connected to an AC supply. One with a leading power factor but still just a load as far as how it interacts with other items other than it would exchange VAR's with inductive loads instead of letting them totally be exchanged with the source. Applying right size capacitor to the DC side of the LED driver would have better results - but this is why you pay more for better designed LED equipment. Most LED's that are direct replacement for an incandescent lamp are built pretty cheaply.Has anyone tried putting a run capacitor on a cord and plugging it into the the receptacle feeding the offending appliance?
Just like disposable built-in socket base ballast vs $20+ T8 ballast.Wouldn't the capacitor just become a load when connected to an AC supply. One with a leading power factor but still just a load as far as how it interacts with other items other than it would exchange VAR's with inductive loads instead of letting them totally be exchanged with the source. Applying right size capacitor to the DC side of the LED driver would have better results - but this is why you pay more for better designed LED equipment. Most LED's that are direct replacement for an incandescent lamp are built pretty cheaply.
