electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
the only time increasing voltage means less current is when the equipment is designed and built to consume a given power with a different applied voltage.
A good example of that is a multi voltage ballast or LED driver. Seems like most now can take anywhere from 100-277V and the wattage is the same (probably efficiency varies a bit over that range, but ignoring that). But a resistive load is too dumb to change its resistance, although there are some special cases of things like certain "self regulating" heating cables made of special alloys where the resistance changes significantly enough with temperature to alter the power consumed.
