Re: Pushmatic Electri-Centers
Both caj and gregory are partially correct, and are in fact, correct in what they saw. Bulldog not only made Pushmatic, but I believe also pioneered the Vac-U-Break type disconnect switches. Some time there-after, ITE purchased them. And as has been stated, Siemens purchased ITE after that. What is not exactly accurate is that there were panels built that were not only "split-bus" type; they were just regular MB or MLO type configurations. I did have an electrician working on a pseudo-3 phase version that was injured because things inside were not as you , [or he] would think. Breakers are hard and expensive to come by; I had to purchase a factory 2-pole 100A main but had to wait 5 months for delivery. I had forgot I ordered it, delivery took so long. I have also had difficulty with breakers opening, but with no visual indication; requiring the use of a meter to confirm output.
I would get on the upgrade it if you can bandwagon.
