Mikemezz
- Southampton, NY
What should the conductor size on a PV system with five 10k inverters each 27.79amps x 1.25 = 34.73 amp be between 175amp AC combiner panel and the 175amp linetap disconnect.
We are using NEC 2008 does the wire size need to be the sumof 2 x 175amps are we required to use cable rated at 350amp.
