- Windsor, CO NEC: 2023
- Hospital Master Electrician
Re: PV Inverters
Both inverters would be on virtually all the time, it seems to me.
In general, to keep one of his inverters "off" as he desires, I'd have to have a 120V-only panel, and then a small panel for his 240V concerns. Wouldn't I?
I mean, a 120V load on inverter "A". When the neutral completes the circuit, wouldn't it tickle "B"'s neutral, kicking it on?Originally posted by physis:
The Samtronix inverters that I use aren't ticklish.Some neutral current would be tickling the unused inverter![]()
If you have a motor and an open switch connected in series across outputs A and B what's happening that would involve the neutral?
Wouldn't that be the case if I breakered the panel only on the "A" phase?Edit: If the B output is used to make the 240 for the pump, and the pump switch is open, there is no circuit through the B inverter. No neutral concerns. Only the A output inverter is working.
