topham26
- Glassboro, NJ
Hi,
my question is specific to PVwire as it compares to USE-2 wiring.
I am designing a 1000Vdc/string array with a transformer-less (non-isolated) inverter, so I must use PVwire.
Since in the NEC the ampacity values are given by temperature with corresponding wire types, PV wire is rated to 120C rather than 90C, does anyone know about the possibility that I could rate my conductors smaller than what the NEC suggests? With volt drop aside.
could I do this, even if not with respect to the NEC would it be possible no problems occur, or could I even do this with respect to the NEC?
Thanks
Jon
Thanks
Jon
