PVC As A Riser?
To each his own. I'm not a PVC riser only lectrian.
I care and it can leak alot. When the bottom edge of a clapboard or shake is butted up against the threads going into the hub it will go all the way to the panel
I have never noticed condensation dripping from the inside of a PVC riser onto to meter terminals before. I sure it happens under the right circumstances.
PVC doesn't change temp fast enough to cause condensation easily, but can happen.
