I was reading any posts I could find on this topic - but I'm still confused on the primer. The supply house I typically deal with also does not stock primer - a comment that seemed to echo in a previous post on PVC. How would one know if the primer is compatible with a certain kind of solvent - if they were by a different manufacturer? The primers that I've seen are not the same manufacturer as the supply houses that I buy from.
When using primer, is it just applied like the solvent, simply brushing it on? The primer, I'm assuming is just to help clean the end of the pipe - is that the case?
