PVC Duct Bank Fitting
Sounds like they just telling you the requirements for metal fittings not that you have to use them with PVC.
Tough to interpret. That would be a little crazy to cut off the belled end of each length to install the coupling.
Unless it tells you to do that I would assume that you can use the bell end and ignore what you posted about the metal fittings.
