I have a question about PVC LBS or Red Dot LBS.I have never used PVC for a service up-grade.When I look in the code book at 314.28(2) Angle or U Pulls I am confused.I had to do some work on a 200 amp service.I had to use three LBS to make my mission.If I use PVC LBS they are only 8-inches from hole to hole.If I use 314.28(2) two times six is 12-inches minimum.My $40.00 Red Dots are what I have to use.How can the $10.00 PVC LBS be legal??????? PS,,, Using 2-inch conduit.
