JFletcher
- Williamsburg, VA
yea i Read it ,HDPE isn't permitted to use in buildings ,but ur reply move a question i'd be glad if u tell me about it , here most of buildings ,dwelling units is made of concrete and bricks ,,but i think there are many of USA's buildings depend on other materials like wood .metals .. right?
i wanna ask about the common conduits u using in buildings i think it may be RMC,IMC,EMC ,FMC..? and how do you install it ,i saw the expression concealed and exposed in NEC this mean you install raceways inside walls too and under floors ,how do you make it with different type of walls material there ..?
Thank you
Yes, most buildings here are made of wood or metal, with drywall (gypsum board) covering the inside. Solid concrete/masonry buildings are fairly rare; the only new construction I can think of that would be solid masonry would be jails/prisons. Of the brick buildings you see here, almost none of it is structural support, rather a facade or outer cover, like stucco or siding.
Most conduit is concealed, either inside of walls, above drop (acoustic tile) ceilings, in or under concrete slabs, or underground. Most of it is permitted to be run exposed, tho it often isnt for asthetic reasons; notable exceptions to this are warehouses, farms, and commercial buildings like grocery stores and "Big Box" stores like Wal-Mart, Home Depot, Lowes, etc.
Conduit run in slabs of concrete is laid before the concrete is poured. For walls, it is installed after the framing is completed. Where it transitions from inside a wall to outside, or wall to ceiling, it is sealed. Walls in buildings that have fire ratings would use a fire stop compound around such penetrations. Here, all vertical penetrations require fire stop, regardless of the conduit or wall type, or if the conduit is concealed or exposed.
We drill through brick, concrete walls, and cement block construction all the time to install conduit, tho they are just straight thru-penetrations. Nobody here would demo out a ton of bricks and reinstall them to conceal conduit. The conduit would be installed surface mount on the outside. If the conduit is coming thru the building on the inside, not just into the back of a panel, it might be concealed by a chase, run into an attic or crawlspace/basement, or surface mounted.
I'd say the most common conduit is EMT, followed by RPVC and RMC. Flexible conduits like ENT, FMC, or LFNMC are used mainly for whips, tho voice/data/communication installations may use quite a bit of ENT. With the correct fittings, ENT is also used in concrete pours.
What conduit is chosen is largely dependent on cost and application. Standard ENT for example cannot be run outdoors (no UV resistance) or in air handling spaces (toxic smoke). RMC can be run almost anywhere but is expensive compared to other conduit types.
