davedottcom
When running a wire through pvc pipe under a slab to a Kitchen Island for a GFCI outlet is there anything wrong with simply pulling a 12/2 NM romex through the pipe without terminating the pipe at either end? In other words the pipe is cut off at floor level at both ends. It does not terminate to a box at either end. The one end is in a 2x4 studded wall and the other end is under the "Dead Space" of the Island. Is this a violation of any kind? I'm thinking the pipe should have a female adaptor with a romex clamp screwed into it on each end but I don't know if it's necessary!?!?
Dave
Dave
