wwhitney
- Berkeley, CA
- Retired
OK, you're right, I just checked a HOM250 I had lying around, and pulling off the handle tie, you can turn each pole on and off individually. I see now that the connecting shaft between the pole can just interconnect the trip mechanisms, rather than being actuated whenever the spring tension is released.I'm fairly certain that it does not.
So getting back to the topic of the OP, I expect that the listing standard for breakers requires a handle tie between any poles that are common trip? Meaning if you see a quad that doesn't come with a handle tie between the outer two poles, you know it's not common trip?
Thanks,
Wayne
