JJWalecka
- New England
I'm not sure if I'm installing this to code. Hypothetically, I have a panel with two two?inch nipples mounted into a 8x8 wire way. I install all the brach circuit raceways into the wire way (trough). I install the grounding conductors to a ground bar and run a large single ground through the two inch nipple to save circular area in the nipples for future use. Is that correct? Would I not be creating the lowest impedance path. If so what table would I use to size the ground accordingly. Thank you for your time and effort.
Justin
Justin
