Thanks221119-231 EDT
Gold should plated over nickel because gold is pourus, and nickel is not. If you use gold only, then you probably want gold thicker than at least 50 millionths.
Gold contacts for low voltage signal circuits are a great advantage at little cost.
However, there are some environments where gold is even a problem. Here a reed switch may be a better choice.
