petersonra
- Northern illinois
- Semi-retired engineer
B
You right... I missed the key-word Minimum Thank you,, very helpful
And you would answer wrong. The simple truth is the" minimum" size GEC for a service be it 400, 1000, 3000, 5,000 amp or what ever is a #6 copper.What is the minimum size of grounding electrode required to handle 3,000 AMPS 460 Volts.
A. 4
B. 6
C. 3/0
D. 400kcmil
There is not specification of what type of electrodes will be used, the only info provided was : (what is the minimum size of grounding electrode required to handle 3,000AMPS 460 Volts), table 250.66 show for a 1100 KCMIL OR OVER use #3/0 Copper for grounding ELECTRODE. That would be my answer..
If the question specified an electrode, say a metallic water pipe, you would be right but since there is no specified electrode it is very possible it could be a lowly rod and the Table doesn't come into play.
Roger
This appears to be worded like a WI masters test question. IIRC
So what is the Most correct answer based on the info given? #6 IMO
MINIMUM GEC with the limited info.
Gotta admit my knee jerk thought was 3/0 but the do say Minimum and do not specify the electrodes.
A poorly written question for a qualifying test.
