Mr. Serious
- Oklahoma, USA
- Electrical Contractor
I've done this only once, on my first job after becoming a contractor: purchased a nice NEMA 12 rated box, with a hinged door, and a steel backplane, and I mounted three terminal blocks in it. The part number of the blocks was ALP2P2. They come with four holes around the outside edges for screws or whatever, so what I did was carefully mark center locations for my screws on the metal, and drill and tap 12 holes for machine screws, then mount the things with machine screws and washers.
The metal backplane was thick, and it took hours to drill and tap 12 holes. I know this isn't how the professionals do it. So, what do you do when you have to mount things on a thick peice of steel in the back of a box?
I just saw an ad for terminal blocks, and it mentioned something about "track mountable." So, DIN rails, is that what they're called? I'm not sure if that's a viable option for the blocks I was talking about, because they're big, for up to 350MCM wire or something like that.
