480sparky said:Millions of people living north of the Mason-Dixon line. They like having toasty warm floors. It's also done for ice-melting in driveways and walkways.
ok but isn't that usually in the form of wiring not radiant pipes under the floor?480sparky said:Millions of people living north of the Mason-Dixon line. They like having toasty warm floors. It's also done for ice-melting in driveways and walkways.
steelersman said:ok but isn't that usually in the form of wiring not radiant pipes under the floor?
steelersman said:I've never heard of the hot water supply pipe running underneath the slab of a home!!! Who would do that?
iwire said:480, I don't think amptech is talking about radiant heat, I think he is talking about the normal plumbing.
I am confident that there are tons of things I haven't heard of, seen or thought of. I tend to think inside the box alot. I'm still learning. Sorry for offending you ben. I'll try to chill out a bit. But I still gotta ask why do they run water pipes under the slab not minus the ones for radiant heat?benaround said:steelersman, There are lots of things you may not of seen so far in your life,
you seem to insinuate that members are making up stories, how about chill a
little bit before posting. Maybe it's just me !!
In Arizona, all the water pipes are run under the slab.
You're right I've never heard of that guy. I've seen a few episodes back in the day with Bob Vila. I heard he had a cocaine problem. Anyone else hear about that?iwire said:You obviously do not watch Dick Trethewey on this old house.
He is always pushing hydronic-radiant-floor-heat. It is becoming very popular in my area.
I would like to retrofit it in my own home.
steelersman said:I don't see how your return duct would pull in hot outside air even if it was split or broken or whatever since return air ducts don't have a path to the outside air (at least not any that I've seen in a house). Could you explain please?
steelersman said:I am confident that there are tons of things I haven't heard of, seen or thought of. I tend to think inside the box alot. I'm still learning. Sorry for offending you ben. I'll try to chill out a bit. But I still gotta ask why do they run water pipes under the slab not minus the ones for radiant heat?
I've never seen them in the attic either. They are always run inside the walls or ceilings around here. At least they're accessible if something goes wrong if they're not in the slab.jrannis said:We have slab on grade construstion in South Florida. No basements due to the high water table here.
I would rather have my supply lines under the slab than in my attic.
what could possibly be making her electric bill $800-$1000 a month.!!
they're running a farm operation they can't tell you about.
I disagree. A watt is a watt. It doesn't matter if the load is 120V or 240V.If the house load is not evenly distributed among the two bus bars then there will be a higher than usualy nuetral load which is basically wasted power that they are paying for and would make the bill higher than normal.
