JJWalecka
- New England
The structural steel is used as one of Grounding Electrode (per 250.52 Grounding Electrodes) for the building service. Do I need to bond the steel for a Separately Derived System, derived from that service equipment [per 250.30 exception to (1)(2) and (3)]?
250.52 Grounding Electrodes.
250.52(A)Electrodes permitted for Grounding
250.52 (A)(2) Metal Frame of the building or Structure. The metal frame of the building or structure, where effectively grounded.
250.30 Grounding Separately Derived alternating current systems.
250.30 (A)(2)Grounding Electrode Conductor. The grounding electrode conductor shall be installed in accordance with (a) or (b). Where taps are connected to a common grounding electrode conductor, the installation shall comply with 250.30(A)(3)
250.30(A)(3) Grounding Electrode Conductor taps. It shall be permissible to connect taps from a separately derived system to a common grounding electrode. Each tap conductor shall connect the grounded conductor of the Separately derived system to the common grounding electrode conductor.
250.30(A)(3)(d) Bonding where exposed structural steel that is interconnected to form the building frame or interior metal piping exists in the area served by the Separatelys derived system, it shall be bonded to the grounding electrode conductor in accordance with 250.104
250.30 (A)(4) Grounding Electrode. The grounding electrode shall be as near as practicable to and preferably in the same area as the grounding electrode conductor connection to the system. The grounding electrode shall be one of the following:
(1) an effectively grounded Structural member of the structure
(2) An effectively grounded metal water pipe within (5ft) from the point of entrance.
EXCEPTION to (1)(2), and (3): Where a separately derived system originates in a listed equipment suitable for the use as service equipment, the grounding electrode used for the service or feeder shall be permitted as the grounding electrode for the Separately derived system, provided the grounding electrode is of sufficient size for the separately derived system. Where the equipment ground bus internal to the service equipment is not smaller than the required grounding electrode conductor, the grounding electrode conductor shall be permitted to be made to the bus.
Thank you for your time and effort.
Justin W.
Justin W.
