LarryFine
- Henrico County, VA
- Electrical Contractor
Yes, but the spinning reserve is mechanical, in the sense of generator inertia. There is extra ampacity in 'reserve,' not actually power that's being generated. The current, and thus the power, will still vary with changes in load.You are correct, the spinning reserve is the available generation in case of the loss of the largest unit or tie feeder. It is the capacity that is available, not excess MWs that are just hanging around on the grid.
It's impossible for more power to be generated than is consumed. Less current will flow, that's all. Power is still volts x amps. If the generators are unloaded some, they will spin easier, requiring a reduction in applied torque.
