TedElectric
- Florida
- Electrical Contractor
Hello all,
I have a customer that has two above ground fuel tanks (small ones, 500 gallons each) one is gasoline and the other is off-road diesel. They are both located outdoors, about three feet apart from each other.
The gasoline tank is hand cranked, no power needed. The diesel pump came with a factory supplied 8' "whip" to be plugged into a receptacle (that is the original work order, add outlet for diesel dispenser). We don't do much with hazardous locations, so bear with me. Im thinking the diesel pump would need to be rated for class 1 conditions, which it is clearly not. Even though diesel is not considered "flammable" I believe the pump motor would need to be rated for hazardous locations since they are literally side by side. *I meant to add that the diesel pump motor in about 60" off the ground, would that get be high enough to be out of the hazardous zone?
Thanks so much for your time, any information will be greatly appreciated.
Ted F
Ted F
