Question on 24VDC Honeywell DI card
All,
Can someone tell me if I have wired up N.O. contact correctly on attached PDF? Does +24vdc land on common terminal or NO terminal? Does it matter on a dry contact? Any links or explanations on this matter would be appreciated.
Thanks in advance,
DavidThanks in advance,
David
  • DI level connection.pdf
All,
Can someone tell me if I have wired up N.O. contact correctly on attached PDF? Does +24vdc land on common terminal or NO terminal? It will work correctly either way. Does it matter on a dry contact? Any links or explanations on this matter would be appreciated.
Thanks in advance,
David
Your plant may have a convention they follow, but as far as actually working it does not matter.
